Configures or unconfigures a front panel port as the designated loopback port for hardware-assisted ELRP.
| elrp-client | Configures ELRP client. |
| hardware-assist | Selects configuring hardware-assisted ELRP. |
| loopback-port | Designates selecting a loopback port for hardware-assisted ELRP. |
| port | Selects the loopback port. The port must be an unused front panel port. |
| none | Unconfigures a loopback port. |
N/A.
The loopback port must be an unused front panel port. The selected loopback port cannot be part of a VLAN. The loopback port cannot be changed or unconfigured if hardware-assisted ELRP mode is enabled. To disable hardware-assisted ELRP, use the command disable elrp-client .
The following example configures port 7 as the loopback port for hardware-assisted ELRP:
# configure elrp-client hardware-assist loopback-port 7
The following example unconfigures the loopback port for hardware-assisted ELRP:
# configure elrp-client hardware-assist loopback-port none
This command was first available in ExtremeXOS 30.3.
